주요 콘텐츠로 건너뛰기
Blu Studio 5.5 S Motherboard Replacement
필요한 것
  1. Blu Studio 5.5 S Motherboard Replacement, Back Casing: 1 단계, 이미지 1/1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Motherboard Replacement, Applying Pressure: 2 단계, 이미지 1/3 Blu Studio 5.5 S Motherboard Replacement, Applying Pressure: 2 단계, 이미지 2/3 Blu Studio 5.5 S Motherboard Replacement, Applying Pressure: 2 단계, 이미지 3/3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Motherboard Replacement, Battery: 3 단계, 이미지 1/3 Blu Studio 5.5 S Motherboard Replacement, Battery: 3 단계, 이미지 2/3 Blu Studio 5.5 S Motherboard Replacement, Battery: 3 단계, 이미지 3/3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Motherboard Replacement, Midframe: 4 단계, 이미지 1/3 Blu Studio 5.5 S Motherboard Replacement, Midframe: 4 단계, 이미지 2/3 Blu Studio 5.5 S Motherboard Replacement, Midframe: 4 단계, 이미지 3/3
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Motherboard Replacement, Aesthetic Bottom Case: 5 단계, 이미지 1/1
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Motherboard Replacement: 6 단계, 이미지 1/3 Blu Studio 5.5 S Motherboard Replacement: 6 단계, 이미지 2/3 Blu Studio 5.5 S Motherboard Replacement: 6 단계, 이미지 3/3
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Motherboard Replacement, Motherboard: 7 단계, 이미지 1/3 Blu Studio 5.5 S Motherboard Replacement, Motherboard: 7 단계, 이미지 2/3 Blu Studio 5.5 S Motherboard Replacement, Motherboard: 7 단계, 이미지 3/3
    • Remove the three 7 mm screws using the Phillips #00 Screwdiver.
    • Disconnect motherboard plug connector near bottom right of battery using fingers to pull off the cap plug.
  8. Blu Studio 5.5 S Motherboard Replacement: 8 단계, 이미지 1/3 Blu Studio 5.5 S Motherboard Replacement: 8 단계, 이미지 2/3 Blu Studio 5.5 S Motherboard Replacement: 8 단계, 이미지 3/3
    • Use the nylon spudger to lift the release tabs by carefully grabbing the tabs from the sides and lifting up.
    • Release the four ribbon wires from the motherboard.
  9. Blu Studio 5.5 S Motherboard Replacement: 9 단계, 이미지 1/2 Blu Studio 5.5 S Motherboard Replacement: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to grip the bottom of the motherboard and lift up.
결론
After the final step has been completed, the replacement motherboard can then be put in place of the old one. To reassemble your device, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Guna Sathyamurthy
회원 가입일: 03/04/17
138 평판
안내서 1개 작성함
IUPUI, Team S2-G2, Wilson Spring 2017 IUPUI, Team S2-G2, Wilson Spring 2017 회원
IUPUI-WILSON-S17S2G2
5 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 502
