주요 콘텐츠로 건너뛰기
Blu Studio 5.5 S Screen Replacement
필요한 것
  1. Blu Studio 5.5 S Screen Replacement, Back Casing: 1 단계, 이미지 1/1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Screen Replacement, Applying Pressure: 2 단계, 이미지 1/3 Blu Studio 5.5 S Screen Replacement, Applying Pressure: 2 단계, 이미지 2/3 Blu Studio 5.5 S Screen Replacement, Applying Pressure: 2 단계, 이미지 3/3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Screen Replacement, Battery: 3 단계, 이미지 1/3 Blu Studio 5.5 S Screen Replacement, Battery: 3 단계, 이미지 2/3 Blu Studio 5.5 S Screen Replacement, Battery: 3 단계, 이미지 3/3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Screen Replacement, Midframe: 4 단계, 이미지 1/3 Blu Studio 5.5 S Screen Replacement, Midframe: 4 단계, 이미지 2/3 Blu Studio 5.5 S Screen Replacement, Midframe: 4 단계, 이미지 3/3
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Screen Replacement, Aesthetic Bottom Case: 5 단계, 이미지 1/1
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Screen Replacement: 6 단계, 이미지 1/3 Blu Studio 5.5 S Screen Replacement: 6 단계, 이미지 2/3 Blu Studio 5.5 S Screen Replacement: 6 단계, 이미지 3/3
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Screen Replacement, Motherboard: 7 단계, 이미지 1/3 Blu Studio 5.5 S Screen Replacement, Motherboard: 7 단계, 이미지 2/3 Blu Studio 5.5 S Screen Replacement, Motherboard: 7 단계, 이미지 3/3
    • Remove the three 7 mm screws using the Phillips #00 Screwdiver.
    • Disconnect motherboard plug connector near bottom right of battery using fingers to pull off the cap plug.
  8. Blu Studio 5.5 S Screen Replacement: 8 단계, 이미지 1/3 Blu Studio 5.5 S Screen Replacement: 8 단계, 이미지 2/3 Blu Studio 5.5 S Screen Replacement: 8 단계, 이미지 3/3
    • Use the nylon spudger to lift the release tabs by carefully grabbing the tabs from the sides and lifting up.
    • Release the four ribbon wires from the motherboard.
  9. Blu Studio 5.5 S Screen Replacement: 9 단계, 이미지 1/2 Blu Studio 5.5 S Screen Replacement: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to grip the bottom of the motherboard and lift up.
  10. Blu Studio 5.5 S Screen Replacement, Screen: 10 단계, 이미지 1/2 Blu Studio 5.5 S Screen Replacement, Screen: 10 단계, 이미지 2/2
    • Remove speaker circuit board from bottom of the phone by using a Spudger to gently lift up.
    • The speaker circuit board is attached with adhesive. Be careful not to break when removing.
    • Once this piece is removed, you can replace your part with the new screen and digitizer assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Greg Cerabona
회원 가입일: 03/04/17
167 평판
안내서 1개 작성함
IUPUI, Team S2-G2, Wilson Spring 2017 IUPUI, Team S2-G2, Wilson Spring 2017 회원
IUPUI-WILSON-S17S2G2
5 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 987
