주요 콘텐츠로 건너뛰기
Blu Studio 5.5 Sub PCBA Replacement
필요한 것
  1. Blu Studio 5.5 Sub PCBA Replacement, Battery: 1 단계, 이미지 1/3 Blu Studio 5.5 Sub PCBA Replacement, Battery: 1 단계, 이미지 2/3 Blu Studio 5.5 Sub PCBA Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the notch to remove the back panel at the lower left corner of the panel.
    • Insert the plastic opening tool or a fingernail into the notch.
    • Apply force upwards until back panel becomes loosened.
  2. Blu Studio 5.5 Sub PCBA Replacement: 2 단계, 이미지 1/2 Blu Studio 5.5 Sub PCBA Replacement: 2 단계, 이미지 2/2
    • Remove the loosened back panel and set aside.
    • Locate the notch to remove the battery.
  3. Blu Studio 5.5 Sub PCBA Replacement: 3 단계, 이미지 1/3 Blu Studio 5.5 Sub PCBA Replacement: 3 단계, 이미지 2/3 Blu Studio 5.5 Sub PCBA Replacement: 3 단계, 이미지 3/3
    • Insert a plastic opening tool or your fingernail into the notch and apply force upwards until the battery is loosened.
    • Remove the battery and set aside.
  4. Blu Studio 5.5 Sub PCBA Replacement, Back Panel Assembly: 4 단계, 이미지 1/2 Blu Studio 5.5 Sub PCBA Replacement, Back Panel Assembly: 4 단계, 이미지 2/2
    • Locate all twelve screws along the back panel:
    • Seven 5mm screws.
    • Five 3.5mm screws.
    • Using a Phillips #000 screwdriver, remove all twelve screws.
  5. Blu Studio 5.5 Sub PCBA Replacement: 5 단계, 이미지 1/3 Blu Studio 5.5 Sub PCBA Replacement: 5 단계, 이미지 2/3 Blu Studio 5.5 Sub PCBA Replacement: 5 단계, 이미지 3/3
    • Now that all the screws have been removed, use a plastic opening tool to carefully pry at each of the corners until loosened.
    • Be extra careful when prying open as it may damage or snap the thin sides of the panel.
    • Place the plastic opening tool inside the loosened panel and gently push upwards and move along the phone to remove the back panel.
    • Remove the panel as if you were turning the page of a book.
  6. Blu Studio 5.5 Sub PCBA Replacement, Sub PCBA: 6 단계, 이미지 1/2 Blu Studio 5.5 Sub PCBA Replacement, Sub PCBA: 6 단계, 이미지 2/2
    • Locate the screw holding down the sub PCBA.
    • Remove the screw using the Phillips #000 screwdriver.
  7. Blu Studio 5.5 Sub PCBA Replacement: 7 단계, 이미지 1/3 Blu Studio 5.5 Sub PCBA Replacement: 7 단계, 이미지 2/3 Blu Studio 5.5 Sub PCBA Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Locate the gold plated cable connecting the sub PCBA to the motherboard.
    • Locate the flex cable connector just above the sub PCBA screw.
    • Using tweezers, detach both cables from the sub PCBA.
  8. Blu Studio 5.5 Sub PCBA Replacement: 8 단계, 이미지 1/2 Blu Studio 5.5 Sub PCBA Replacement: 8 단계, 이미지 2/2
    • Note the red and blue wires connecting the sub PCBA to the speakers.
    • Either the speaker will need to be loosened and removed alongside the sub PCBA or the wires disconnected and resoldered during reassembly.
    • Using tweezers, grab the PCBA and remove gently from assembly.
결론
Alec Coleman
회원 가입일: 02/28/17
313 평판
안내서 3개 작성하였습니다
USF Tampa, Team S1-G6, Nance Spring 2017 USF Tampa, Team S1-G6, Nance Spring 2017 회원
USFT-NANCE-S17S1G6
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 504
