주요 콘텐츠로 건너뛰기
Blu Studio HD 6.0 MicroSD Card Replacement
필요한 것
  1. Blu Studio HD 6.0 MicroSD Card Replacement, Rear Case: 1 단계, 이미지 1/1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 MicroSD Card Replacement, Back Panel.: 2 단계, 이미지 1/2 Blu Studio HD 6.0 MicroSD Card Replacement, Back Panel.: 2 단계, 이미지 2/2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 MicroSD Card Replacement: 3 단계, 이미지 1/2 Blu Studio HD 6.0 MicroSD Card Replacement: 3 단계, 이미지 2/2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 MicroSD Card Replacement, Insert the Micro-SD Card: 4 단계, 이미지 1/3 Blu Studio HD 6.0 MicroSD Card Replacement, Insert the Micro-SD Card: 4 단계, 이미지 2/3 Blu Studio HD 6.0 MicroSD Card Replacement, Insert the Micro-SD Card: 4 단계, 이미지 3/3
    • Find the Micro-SD card slot which is under the right SIM card slot.
    • Line up the gold pins of the Micro-SD card with the pins of the card slot. If pins in the slot are hidden, then insert the Micro-SD card with the "MicroSD" print up and the pins facing the slot.
    • Slide the card into the slot until you either hear a clicking noise or until the card does not move anymore. Do not apply too much force; gently slide it in and stop immediately when it does not move anymore.
  5. Blu Studio HD 6.0 MicroSD Card Replacement, Turn the phone on: 5 단계, 이미지 1/1
    • Your phone should boot up and ask you to format your Micro-SD Card.
    • Format the card and you're good to go.
    • If your phone does not recognize the card, ensure that the gold pins of the card aligned with the gold pins on the phone's Micro-SD slot.
    • If the card is installed correctly, the card may be faulty. If so contact the Micro-SD card manufacturer.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Alec
회원 가입일: 09/23/14
617 평판
안내서 2개 작성하였습니다
USF Tampa, Team 9-1, Blackwell Fall 2014 USF Tampa, Team 9-1, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S9G1
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
Very clear instructions and step by step guidance
Laszlo Tihanyi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 16,341
