소개
You'll need to have your solder workstation ready to use at this point.
Remember, safety first.
필요한 것
To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
After removing all 16 screws you can begin the process of removing the battery housing panel.
You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
Try to be careful around the side buttons as the plastic is weakest there.
After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
Lift the microphone very carefully.
Unsolder the two lower wires ( one red wire and one black wire ).
Solder the new microphone in the same spot. The black wire will go in the lower spot and the red wire in the upper spot.
다른 6명이 해당 안내서를 완성하였습니다.
