주요 콘텐츠로 건너뛰기
Blu Studio HD 6.0 Midframe Replacement
필요한 것
  1. Blu Studio HD 6.0 Midframe Replacement, Rear Case: 1 단계, 이미지 1/1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 Midframe Replacement, Back Panel.: 2 단계, 이미지 1/2 Blu Studio HD 6.0 Midframe Replacement, Back Panel.: 2 단계, 이미지 2/2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 Midframe Replacement: 3 단계, 이미지 1/2 Blu Studio HD 6.0 Midframe Replacement: 3 단계, 이미지 2/2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 Midframe Replacement, Midframe: 4 단계, 이미지 1/2 Blu Studio HD 6.0 Midframe Replacement, Midframe: 4 단계, 이미지 2/2
    • With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
  5. Blu Studio HD 6.0 Midframe Replacement: 5 단계, 이미지 1/1
    • Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
    • One of the lower right hand screws will be hidden under a sticker.
  6. Blu Studio HD 6.0 Midframe Replacement: 6 단계, 이미지 1/1
    • After removing all 16 screws you can begin the process of removing the battery housing panel.
    • You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
    • Try to be careful around the side buttons as the plastic is weakest there.
    • After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
  7. Blu Studio HD 6.0 Midframe Replacement: 7 단계, 이미지 1/1
    • At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Erik reinbolt
회원 가입일: 09/23/14
1,572 평판
안내서 3개 작성하였습니다
USF Tampa, Team 9-1, Blackwell Fall 2014 USF Tampa, Team 9-1, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S9G1
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
I have the same phone, This helps me fix the broken screen that i am trying to replace. I need complete screen replacement guide
sandip patel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,047
