주요 콘텐츠로 건너뛰기
Blu Studio HD 6.0 SIM Card Replacement
필요한 것
  1. Blu Studio HD 6.0 SIM Card Replacement, Rear Case: 1 단계, 이미지 1/1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 SIM Card Replacement, Back Panel.: 2 단계, 이미지 1/2 Blu Studio HD 6.0 SIM Card Replacement, Back Panel.: 2 단계, 이미지 2/2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 SIM Card Replacement: 3 단계, 이미지 1/2 Blu Studio HD 6.0 SIM Card Replacement: 3 단계, 이미지 2/2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 SIM Card Replacement, Find out if your Blu Studio 6.0 is "unlocked.": 4 단계, 이미지 1/1
    • Look at the sticker on top of the battery housing and note the model, part number and type.
    • Research this information to find out if you have an unlocked version of the phone.
    • If your phone is unlocked you can use any mobile network SIM card. If not you must replace the SIM card with a card from your carrier.
  5. Blu Studio HD 6.0 SIM Card Replacement, Installing the SIM Card: 5 단계, 이미지 1/3 Blu Studio HD 6.0 SIM Card Replacement, Installing the SIM Card: 5 단계, 이미지 2/3 Blu Studio HD 6.0 SIM Card Replacement, Installing the SIM Card: 5 단계, 이미지 3/3
    • If necessary slide the unneeded SIM card out of it's slot.
    • Make sure your new SIM card has been activated by the carrier.
    • Take the front end tip of the SIM card (the side with the corner cut) and slide it gently into the SIM card slot.
  6. Blu Studio HD 6.0 SIM Card Replacement, Turn the phone on: 6 단계, 이미지 1/1
    • Turn on your Studio 6.0 and test it to make sure that everything is working.
    • If your phone gives you an error, check your SIM card installation. If everything seems to be correct make sure your SIM card is activated.
    • If everything is working you're good to go.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Alec
회원 가입일: 09/23/14
617 평판
안내서 2개 작성하였습니다
USF Tampa, Team 9-1, Blackwell Fall 2014 USF Tampa, Team 9-1, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S9G1
3 회원들
안내서 8개 작성하였습니다
댓글 13개
Okay so my Sim has been working for months just 2 days ago my phone wouldn't turn on and then we'll now it doesn't read the Sim card idk what's going on with this but its getting annoying
caitlin - 답글
i know i am having the same issue. it is saying my sim card is off and to turn it on
jsllndr84 -
Its saying my Sim card is off..how do I turn it on.
victor ayitey - 답글
I just got this phone and I install the sim card like they say and it still says no sim card
Cheryl Dean - 답글
I have activated metro pcs sim. Unlocked blu studio g2 6.0 will not detect sim wtf?
Tim - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 41
전체 시간: 45,057
