주요 콘텐츠로 건너뛰기
Blu Studio Selfie Battery Replacement
필요한 것
  1. Blu Studio Selfie Battery Replacement, Rear Cover: 1 단계, 이미지 1/1
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. Blu Studio Selfie Battery Replacement: 2 단계, 이미지 1/1
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
  3. Blu Studio Selfie Battery Replacement, Battery: 3 단계, 이미지 1/2 Blu Studio Selfie Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Stacy Kam
회원 가입일: 01/20/16
630 평판
안내서 5개 작성하였습니다
USF Tampa, Team 10-1, Remmell Spring 2016 USF Tampa, Team 10-1, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 1,313
