주요 콘텐츠로 건너뛰기
Blu Studio Selfie Rear Cover Replacement
필요한 것
  1. Blu Studio Selfie Rear Cover Replacement, Rear Cover: 1 단계, 이미지 1개 중 1개
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. Blu Studio Selfie Rear Cover Replacement: 2 단계, 이미지 1개 중 1개
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Stacy Kam
회원 가입일: 01/20/16
630 평판
안내서 5개를 작성함
USF Tampa, Team 10-1, Remmell Spring 2016 USF Tampa, Team 10-1, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G1
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 5
전체 시간: 294
