주요 콘텐츠로 건너뛰기
Blueair 311 Auto: Disassembly and disconnection of ionizer
필요한 것
  1. Blueair 311 Auto: Disassembly and disconnection of ionizer, Remove the top fan housing from the base: 1 단계, 이미지 1개 중 1개
    • Unplug the power adapter of the air filter
    • Grab the top (white) housing, rotate it counter-clockwise, and lift it to detach it from the base.
  2. Blueair 311 Auto: Disassembly and disconnection of ionizer, Remove screws: 2 단계, 이미지 2개 중 1개 Blueair 311 Auto: Disassembly and disconnection of ionizer, Remove screws: 2 단계, 이미지 2개 중 2개
    • Rotate the filter top to be upside down.
    • Remove the 4 phillips head screws (red)
    • Remove the 4 phillips head screws (blue). These screws need a long/skinny screwdriver to reach, as they are sunk into plastic holes. But, they seem to be the same screws as the red screws.
    • Optionally, you can remove the 1 screw holding on the LED for the indicator on the front, and the plastic tab for the (presumably) particle sensing, but it is easier to reassemble if you do not remove those fasteners.
  3. Blueair 311 Auto: Disassembly and disconnection of ionizer, Lift the black top from the white housing: 3 단계, 이미지 1개 중 1개
    • Lift the black top from the white housing. Lift from the side where the white clips are.
  4. Blueair 311 Auto: Disassembly and disconnection of ionizer, Disconnect the ionizer power cable: 4 단계, 이미지 3개 중 1개 Blueair 311 Auto: Disassembly and disconnection of ionizer, Disconnect the ionizer power cable: 4 단계, 이미지 3개 중 2개 Blueair 311 Auto: Disassembly and disconnection of ionizer, Disconnect the ionizer power cable: 4 단계, 이미지 3개 중 3개
    • Unclip the connector for the 2-wire ionizer power cable, and disconnect if from the printed circuit board (PCB)
    • Note: It is possible & easier to unclip the connector, without fully removing the PCB, i.e. by reaching behind the PCB, and applying pressure purely by the feeling of the clip, to unclip it. These photos are just for clarity.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
photocyte
회원 가입일: 07/02/20
136 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 39
지난 30일: 166
전체 시간: 3,747
