주요 콘텐츠로 건너뛰기
Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement
필요한 것
  1. Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Symptoms - Before getting started.: 1 단계, 이미지 3개 중 1개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Symptoms - Before getting started.: 1 단계, 이미지 3개 중 2개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Symptoms - Before getting started.: 1 단계, 이미지 3개 중 3개
    • Power LED on, water level not dropping or stopped dropping on brewing.
    • After opening the base cover, you can check the thermal cutoff fuse by measuring resistance between Neutral - the white wire from power plug and the contact at lower of water heater (which is behind the metal plate below the water heater connecting to Ground - green wire)
    • If the resistance level is indefinite (cutoff), this mean you have a brown fuse.
    • If Power LED cannot turn on, you might have problem with one of microswitch, water level sensor and jug position sensor. In this case, you might try to clean the microswitch with electronic contact cleaner.
  2. Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Removable parts & water.: 2 단계, 이미지 3개 중 1개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Removable parts & water.: 2 단계, 이미지 3개 중 2개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Removable parts & water.: 2 단계, 이미지 3개 중 3개
    • Remove jug, filter and water tank.
    • Open the top cover and remove the silicone "showerhead".
    • Empty remaining water by putting it upside down over kitchen sink.
  3. Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Open the base.: 3 단계, 이미지 3개 중 1개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Open the base.: 3 단계, 이미지 3개 중 2개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Open the base.: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Remove the base by sliding a plastic opening tool or a flat blade screwdriver from the corner.
    • Slide plastic card and gradually open the whole base.
  4. Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Remove round platter securing the lower body.: 4 단계, 이미지 3개 중 1개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Remove round platter securing the lower body.: 4 단계, 이미지 3개 중 2개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Remove round platter securing the lower body.: 4 단계, 이미지 3개 중 3개
    • Remove the four screws from the round platter.
    • Notice that there is a small index key which must be aligned on reassembly.
  5. Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Detach top assembly.: 5 단계, 이미지 3개 중 1개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Detach top assembly.: 5 단계, 이미지 3개 중 2개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Detach top assembly.: 5 단계, 이미지 3개 중 3개
    • Slide the plastic opening tool from corner to open the top assembly.
    • Be careful with the silicone vapour pipe on opening. You can also push the pipe head into the hole before opening as it is soft silicone material.
  6. Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Detach the upper connector.: 6 단계, 이미지 3개 중 1개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Detach the upper connector.: 6 단계, 이미지 3개 중 2개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Detach the upper connector.: 6 단계, 이미지 3개 중 3개
    • Slightly bent the plastic hook at corner of the round plastic connector.
    • Carefully detach it from the front side of the body.
  7. Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Pull the front and rear parts apart.: 7 단계, 이미지 3개 중 1개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Pull the front and rear parts apart.: 7 단계, 이미지 3개 중 2개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Pull the front and rear parts apart.: 7 단계, 이미지 3개 중 3개
    • Pull the front and rear parts apart.
  8. Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Check and remove the thermal cutoff fuse.: 8 단계, 이미지 3개 중 1개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Check and remove the thermal cutoff fuse.: 8 단계, 이미지 3개 중 2개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Check and remove the thermal cutoff fuse.: 8 단계, 이미지 3개 중 3개
    • Check if the fuse is brown with multimeter. There should be zero resistance between "Neutral" on the plug and the lower connector of the water heater. (This photo is actually taken after replacement, so the reading is zero.)
    • If the reading from multimeter shown the fuse is disconnected. Loosen the screw and pull out the silicone tube holding the thermal cutoff fuse.
  9. Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Replacing thermal cutoff fuse.: 9 단계, 이미지 3개 중 1개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Replacing thermal cutoff fuse.: 9 단계, 이미지 3개 중 2개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Replacing thermal cutoff fuse.: 9 단계, 이미지 3개 중 3개
    • The thermal cutoff fuse (SF169E, 172°C, 120V 15A) is crimped with copper beads.
    • You can try to loosen the bead and rotate the thermal cutoff fuse to pull it out.
    • Crimp new thermal cutoff fuse and try to rotate and pull to test if its secure enough.
  10. Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Test and secure the thermal cutoff fuse.: 10 단계, 이미지 3개 중 1개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Test and secure the thermal cutoff fuse.: 10 단계, 이미지 3개 중 2개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Test and secure the thermal cutoff fuse.: 10 단계, 이미지 3개 중 3개
    • Measure the resistance of the new thermal cutoff fuse. The reading should be zero.
    • Secure the thermal cutoff fuse and use touch or flash light to make sure it's centred on the bracket. You might need a plier to hold the nut as it's not fixed inside.
  11. Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Reassembly.: 11 단계, 이미지 3개 중 1개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Reassembly.: 11 단계, 이미지 3개 중 2개 Bodum Bistro B.Over Coffeemaker Thermal Cutoff Fuse Replacement, Reassembly.: 11 단계, 이미지 3개 중 3개
    • Put the coffeemaker horizontal and press to secure the front and rear part of body.
    • Replace the top and bottom.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
C Yang
회원 가입일: 06/18/17
349 평판
안내서 1개를 작성함
2가이드 댓글
Have the older version of this Coffee Maker changing the thermal cutoff fuse as above did NOT resolve my issues. (Coffee maker would get HOT very HOT and cutoff/flashing RED light, Some steam but i noticed little water passing up tubes.) A strong sharp blow down both white rubber tubes/pipes (when machine is COLD! seen in step 6) did however fix my issue. (& now it has a new thermal cutoff fitted also) Just cleaning it out now with white vinegar/water solution. Hope this helps someone else.
Drew - 답글
Thank you for the detailed instructions. My Bodum coffee maker has the same symptom of blinking LED and not heating up, but the fuse was not blown. The heating coils have the expected impedance. What other component could be the culprit? Thanks.
Jo Kung-Chiao Hsieh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 16
지난 30일: 43
전체 시간: 5,034
