주요 콘텐츠로 건너뛰기
Body Cover Removal
필요한 것
  1. Body Cover Removal, Remove back cover: 1 단계, 이미지 1개 중 1개
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Body Cover Removal, Remove bottom cover: 2 단계, 이미지 1개 중 1개
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Body Cover Removal, Remove left front cover: 3 단계, 이미지 1개 중 1개
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Body Cover Removal, Remove front cover: 4 단계, 이미지 2개 중 1개 Body Cover Removal, Remove front cover: 4 단계, 이미지 2개 중 2개
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Body Cover Removal, Remove right front cover: 5 단계, 이미지 1개 중 1개
    • Remove two 3.9 mm #00 screws.
결론
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
7,682 평판
안내서 42개를 작성함
댓글 2개
Do you know is the leatherette is removable?
cavjer123 - 답글
It should be. I haven't done it but it is a separate piece from the plastic panels. Try applying some isopropyl alcohol along an edge to soften the adhesive, then work a dull scraper underneath. It should come off without too much effort.
Sam Gustafson -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 359
