주요 콘텐츠로 건너뛰기
Bolide Technology Group Dual Alarm Clock Speaker Replacement
필요한 것
  1. Bolide Technology Group Dual Alarm Clock Speaker Replacement, Speaker: 1 단계, 이미지 1/3 Bolide Technology Group Dual Alarm Clock Speaker Replacement, Speaker: 1 단계, 이미지 2/3 Bolide Technology Group Dual Alarm Clock Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Slide the clear plastic case off of the speaker
  2. Bolide Technology Group Dual Alarm Clock Speaker Replacement: 2 단계, 이미지 1/3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 2 단계, 이미지 2/3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 2 단계, 이미지 3/3
    • Remove the batteries on the bottom of the radio
    • Locate and remove the five screws on the bottom of the radio with a Philips Head Screwdriver.
    • Make sure to keep your screws together so you don't lose them.
  3. Bolide Technology Group Dual Alarm Clock Speaker Replacement: 3 단계, 이미지 1/3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 3 단계, 이미지 2/3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 3 단계, 이미지 3/3
    • Grab your nylon pry tool and wedge it between the outer case and the top of the radio. Slowly pry open the top and remove it.
    • This may be more difficult to take off if the top hasn't been removed before, but it may be easier to turn the clock upside down for this step.
  4. Bolide Technology Group Dual Alarm Clock Speaker Replacement: 4 단계, 이미지 1/2 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Spudger
    $2.99
    구매
    • Using a black nylon spudger to carefully break the glue around the outside of the speaker so it can be dislodged.
  5. Bolide Technology Group Dual Alarm Clock Speaker Replacement: 5 단계, 이미지 1/3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 5 단계, 이미지 2/3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Locate the speaker plug for the speaker you wish to remove and slightly tug on it until it becomes unplugged
    • This can also be done with a pair of tweezers if you find there isn't enough space.
  6. Bolide Technology Group Dual Alarm Clock Speaker Replacement: 6 단계, 이미지 1/2 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 6 단계, 이미지 2/2
    • After the speaker cord is removed, pull the speaker straight up and out of the radio.
  7. Bolide Technology Group Dual Alarm Clock Speaker Replacement: 7 단계, 이미지 1/2 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 7 단계, 이미지 2/2
    • Once the speaker is removed, the inside of the dual alarm clock should look identical to the photo shown.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mercy Adeshola
회원 가입일: 02/20/17
121 평판
안내서 1개 작성함
USF Tampa, Team 10-1, Remmell Spring 2017 USF Tampa, Team 10-1, Remmell Spring 2017 회원
USFT-REMMELL-S17S10G1
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 25
전체 시간: 678
