주요 콘텐츠로 건너뛰기
Bonaok Q37 Battery Replacement
필요한 것
  1. Bonaok Q37 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Power down the microphone before proceeding to the next step.
  2. Bonaok Q37 Battery Replacement: 2 단계, 이미지 1/2 Bonaok Q37 Battery Replacement: 2 단계, 이미지 2/2
    • Hold the handle with your right hand and unscrew towards you.
    • Once the cover is unscrewed completely, remove the handle cover.
  3. Bonaok Q37 Battery Replacement: 3 단계, 이미지 1/2 Bonaok Q37 Battery Replacement: 3 단계, 이미지 2/2
    • Lift up the side edges of the "Caution" sticker to unseal the battery cover.
    • If the battery compartment cover is not sealed with a caution sticker, proceed to Step 4.
  4. Bonaok Q37 Battery Replacement: 4 단계, 이미지 1/2 Bonaok Q37 Battery Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to push the cover towards the left.
    • Lift up the cover to remove it from the microphone.
  5. Bonaok Q37 Battery Replacement: 5 단계, 이미지 1/3 Bonaok Q37 Battery Replacement: 5 단계, 이미지 2/3 Bonaok Q37 Battery Replacement: 5 단계, 이미지 3/3
    • Push the battery towards the left and lift it up from the (+) side.
    • Remove the battery from the compartment.
  6. Bonaok Q37 Battery Replacement: 6 단계, 이미지 1/1
    • Insert a new battery into the compartment.
    • Make sure you insert the (-) end first, then push towards the left to make room for the whole battery to be pushed into the compartment.
  7. Bonaok Q37 Battery Replacement: 7 단계, 이미지 1/3 Bonaok Q37 Battery Replacement: 7 단계, 이미지 2/3 Bonaok Q37 Battery Replacement: 7 단계, 이미지 3/3
    • Close the lid and seal back with the caution sticker.
    • Screw the handle back on by twisting it away from you.
  8. Bonaok Q37 Battery Replacement: 8 단계, 이미지 1/1
    • Turn the power on and make sure the operating light is blue.
결론
Please charge the device completely before use.
Han Sol Lee
회원 가입일: 01/17/22
157 평판
안내서 1개 작성함
York University, Team 1-16, O'Regan Winter 2022 York University, Team 1-16, O'Regan Winter 2022 회원
YORK-O'REGAN-W22S1G16
1 회원
안내서 1개 작성하였습니다
댓글 4개
What kind of battery?
Carmen Veguilla - 답글
Which type of battery? I looked on Amazon but can't find it. Must be age related problem, too old for new tech. 😊
Where can I buy replacement battery
Lee Fisher - 답글
NUMBER 18650 3.7volt lithium-ion rechargeable, available online everywhere BUT cannot ship with most carriers so delivery charge is expensive
William Row - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 63
전체 시간: 1,724
