주요 콘텐츠로 건너뛰기
Boosted Board 1st Generation Belts Replacement
필요한 것
  1. Boosted Board 1st Generation Belts Replacement, Rear Wheels: 1 단계, 이미지 2개 중 1개 Boosted Board 1st Generation Belts Replacement, Rear Wheels: 1 단계, 이미지 2개 중 2개
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Belts Replacement: 2 단계, 이미지 1개 중 1개
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Belts Replacement: 3 단계, 이미지 2개 중 1개 Boosted Board 1st Generation Belts Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Belts Replacement: 4 단계, 이미지 3개 중 1개 Boosted Board 1st Generation Belts Replacement: 4 단계, 이미지 3개 중 2개 Boosted Board 1st Generation Belts Replacement: 4 단계, 이미지 3개 중 3개
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Belts Replacement, Belts: 5 단계, 이미지 3개 중 1개 Boosted Board 1st Generation Belts Replacement, Belts: 5 단계, 이미지 3개 중 2개 Boosted Board 1st Generation Belts Replacement, Belts: 5 단계, 이미지 3개 중 3개
    • Compress the motor mount back .
    • Slide the belt off the axle
  6. Boosted Board 1st Generation Belts Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two hex screws.
    • Remove the front hex screw.
    • When removing the Front hex screw, hold the motor mount and the truck together.
    • The springs inside the motor mount will push the motor out of the casing if they are not held together.
  7. Boosted Board 1st Generation Belts Replacement: 7 단계, 이미지 3개 중 1개 Boosted Board 1st Generation Belts Replacement: 7 단계, 이미지 3개 중 2개 Boosted Board 1st Generation Belts Replacement: 7 단계, 이미지 3개 중 3개
    • Making sure to hold the motor and truck together, lift off the belt casing and take off the belt.
    • Do Not let go of the motor and truck until the new belt is on and the Front hex screw is tightened securely.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Emily Imfeld
회원 가입일: 10/06/16
532 평판
안내서 4개를 작성함
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G7
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 1,765
