주요 콘텐츠로 건너뛰기
Boosted Board 1st Generation Rear Wheels Replacement
필요한 것
  1. Boosted Board 1st Generation Rear Wheels Replacement, Rear Wheels: 1 단계, 이미지 1/2 Boosted Board 1st Generation Rear Wheels Replacement, Rear Wheels: 1 단계, 이미지 2/2
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Rear Wheels Replacement: 2 단계, 이미지 1/1
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Rear Wheels Replacement: 3 단계, 이미지 1/2 Boosted Board 1st Generation Rear Wheels Replacement: 3 단계, 이미지 2/2
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Rear Wheels Replacement: 4 단계, 이미지 1/3 Boosted Board 1st Generation Rear Wheels Replacement: 4 단계, 이미지 2/3 Boosted Board 1st Generation Rear Wheels Replacement: 4 단계, 이미지 3/3
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
결론
Emily Imfeld
회원 가입일: 10/06/16
532 평판
안내서 4개 작성하였습니다
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G7
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,258
