주요 콘텐츠로 건너뛰기
Boosted Board 1st Generation Skateboard Bearings Replacement
필요한 것
  1. Boosted Board 1st Generation Skateboard Bearings Replacement, Rear Wheels: 1 단계, 이미지 2개 중 1개 Boosted Board 1st Generation Skateboard Bearings Replacement, Rear Wheels: 1 단계, 이미지 2개 중 2개
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Skateboard Bearings Replacement: 2 단계, 이미지 1개 중 1개
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Skateboard Bearings Replacement: 3 단계, 이미지 2개 중 1개 Boosted Board 1st Generation Skateboard Bearings Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Skateboard Bearings Replacement: 4 단계, 이미지 3개 중 1개 Boosted Board 1st Generation Skateboard Bearings Replacement: 4 단계, 이미지 3개 중 2개 Boosted Board 1st Generation Skateboard Bearings Replacement: 4 단계, 이미지 3개 중 3개
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Skateboard Bearings Replacement, Skateboard Bearings: 5 단계, 이미지 2개 중 1개 Boosted Board 1st Generation Skateboard Bearings Replacement, Skateboard Bearings: 5 단계, 이미지 2개 중 2개
    • Use one finger to pull out the pulley bearing.
    • A good technique is to go around in a circle and lift from underneath the bearing in a carving motion.
  6. Boosted Board 1st Generation Skateboard Bearings Replacement: 6 단계, 이미지 3개 중 1개 Boosted Board 1st Generation Skateboard Bearings Replacement: 6 단계, 이미지 3개 중 2개 Boosted Board 1st Generation Skateboard Bearings Replacement: 6 단계, 이미지 3개 중 3개
    • Use an Allen wrench to apply pressure to the inside edge of the bearing until it pops out
  7. Boosted Board 1st Generation Skateboard Bearings Replacement: 7 단계, 이미지 3개 중 1개 Boosted Board 1st Generation Skateboard Bearings Replacement: 7 단계, 이미지 3개 중 2개 Boosted Board 1st Generation Skateboard Bearings Replacement: 7 단계, 이미지 3개 중 3개
    • Replace bearing by dropping it in the center of the wheel and use a socket wrench to pop in back it place
  8. Boosted Board 1st Generation Skateboard Bearings Replacement: 8 단계, 이미지 3개 중 1개 Boosted Board 1st Generation Skateboard Bearings Replacement: 8 단계, 이미지 3개 중 2개 Boosted Board 1st Generation Skateboard Bearings Replacement: 8 단계, 이미지 3개 중 3개
    • Slide the bearing spacer on to an Allen wrench
    • Align the Allen wrench in the center of the bearing and drop the spacer directly in the middle
    • Repeat Step 7 for placing the bearing in this side of the wheel.
결론
To reassemble your device, follow these directions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Emily Imfeld
회원 가입일: 10/06/16
532 평판
안내서 4개를 작성함
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G7
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 883
