주요 콘텐츠로 건너뛰기
Boot Zipper Replacement
필요한 것
  1. Boot Zipper Replacement, Zipper: 1 단계, 이미지 2개 중 1개 Boot Zipper Replacement, Zipper: 1 단계, 이미지 2개 중 2개
    • Using a seam ripper, carefully remove the stitching at the top of the boot on either side of the zipper.
    • Only remove enough to free the zipper, about ¾ of an inch.
  2. Boot Zipper Replacement: 2 단계, 이미지 3개 중 1개 Boot Zipper Replacement: 2 단계, 이미지 3개 중 2개 Boot Zipper Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the stitching on the heel side of the zipper.
    • The stitches on the heel side connect four layers of material: the lining, the zipper underlay, the zipper, and the outer leather.
    • Work between the leather and the zipper by pulling apart the leather and zipper and inserting the seam ripper into the gap.
  3. Boot Zipper Replacement: 3 단계, 이미지 2개 중 1개 Boot Zipper Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the stitching on the toe side of the zipper.
    • The stitches on the toe side connect three layers of material: the lining, the zipper, and the outer leather.
    • Set aside the original zipper.
  4. Boot Zipper Replacement: 4 단계, 이미지 1개 중 1개
    • Remove any leftover thread.
  5. Boot Zipper Replacement: 5 단계, 이미지 2개 중 1개 Boot Zipper Replacement: 5 단계, 이미지 2개 중 2개
    • Measure your zipper against the boot.
    • Use a pin to mark how long it should be.
  6. Boot Zipper Replacement: 6 단계, 이미지 1개 중 1개
    • If your zipper is too long, trim it about an inch below your pin.
  7. Boot Zipper Replacement: 7 단계, 이미지 2개 중 1개 Boot Zipper Replacement: 7 단계, 이미지 2개 중 2개
    • Fold down the excess fabric at the top of the zipper twice to create a right angle.
  8. Boot Zipper Replacement: 8 단계, 이미지 3개 중 1개 Boot Zipper Replacement: 8 단계, 이미지 3개 중 2개 Boot Zipper Replacement: 8 단계, 이미지 3개 중 3개
    • Stitch in place.
    • Use pliers if the fabric is too thick to push the needle through easily.
  9. Boot Zipper Replacement: 9 단계, 이미지 2개 중 1개 Boot Zipper Replacement: 9 단계, 이미지 2개 중 2개
    • Pin your new zipper to the outer leather on the heel side.
    • Be careful to put your pins through the existing holes in the leather to avoid damaging the leather further.
  10. Boot Zipper Replacement: 10 단계, 이미지 1개 중 1개
    • Using a backstitch, sew the zipper to the leather along the inner row of stitching.
    • Be careful to put your needle through the existing holes in the leather to avoid damaging the leather further.
  11. Boot Zipper Replacement: 11 단계, 이미지 2개 중 1개 Boot Zipper Replacement: 11 단계, 이미지 2개 중 2개
    • Repeat steps 8 and 9 for the toe side of the zipper.
  12. Boot Zipper Replacement: 12 단계, 이미지 2개 중 1개 Boot Zipper Replacement: 12 단계, 이미지 2개 중 2개
    • Pin the lining to the zipper and leather on the toe side.
  13. Boot Zipper Replacement: 13 단계, 이미지 2개 중 1개 Boot Zipper Replacement: 13 단계, 이미지 2개 중 2개
    • Using a backstitch, sew the lining into place along the outer row of stitching.
  14. Boot Zipper Replacement: 14 단계, 이미지 2개 중 1개 Boot Zipper Replacement: 14 단계, 이미지 2개 중 2개
    • Pin the lining and zipper underlay to the zipper and outer leather on the heel side.
  15. Boot Zipper Replacement: 15 단계, 이미지 1개 중 1개
    • Using a backstitch, sew the lining and zipper underlay into place along the outer row of stitching.
  16. Boot Zipper Replacement: 16 단계, 이미지 2개 중 1개 Boot Zipper Replacement: 16 단계, 이미지 2개 중 2개
    • This should be the final outcome after you repair the boot.
결승점
작성자
3다른 기여자 명과 함께
Alex
회원 가입일: 11/05/24
258 평판
안내서 1개를 작성함
UC Davis, Team 4-2, Vidal-Chiesa Fall 2024 UC Davis, Team 4-2, Vidal-Chiesa Fall 2024 회원
UCD-VIDAL-CHIESA-F24S4G2
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 50
지난 30일: 218
전체 시간: 1,544
