주요 콘텐츠로 건너뛰기
Bosch 3727DEVS Governor Replacement
필요한 것
  1. Bosch 3727DEVS Governor Replacement, Governor: 1 단계, 이미지 1/3 Bosch 3727DEVS Governor Replacement, Governor: 1 단계, 이미지 2/3 Bosch 3727DEVS Governor Replacement, Governor: 1 단계, 이미지 3/3
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top off of the sander.
  2. Bosch 3727DEVS Governor Replacement: 2 단계, 이미지 1/3 Bosch 3727DEVS Governor Replacement: 2 단계, 이미지 2/3 Bosch 3727DEVS Governor Replacement: 2 단계, 이미지 3/3
    • Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
    • Lift the cable clip and cord from motor housing.
  3. Bosch 3727DEVS Governor Replacement: 3 단계, 이미지 1/1
    • Lift the On/Off switch out of the device
    • Remove the gray and purple wires
  4. Bosch 3727DEVS Governor Replacement: 4 단계, 이미지 1/2 Bosch 3727DEVS Governor Replacement: 4 단계, 이미지 2/2
    • Remove the gray, brown, and clear wires by pulling on the wire terminals.
    • Lift the Governor out of the housing.
결론
Daniel Riddle
회원 가입일: 01/29/16
331 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 570
