주요 콘텐츠로 건너뛰기
Bosch 3727DEVS Motor Brushes Replacement
필요한 것
  1. Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: 1 단계, 이미지 1/3 Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: 1 단계, 이미지 2/3 Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: 1 단계, 이미지 3/3
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top cover off the sander.
  2. Bosch 3727DEVS Motor Brushes  Replacement: 2 단계, 이미지 1/3 Bosch 3727DEVS Motor Brushes  Replacement: 2 단계, 이미지 2/3 Bosch 3727DEVS Motor Brushes  Replacement: 2 단계, 이미지 3/3
    • Remove the two white wires connected to each motor brush by pulling on the spade terminals.
  3. Bosch 3727DEVS Motor Brushes  Replacement: 3 단계, 이미지 1/3 Bosch 3727DEVS Motor Brushes  Replacement: 3 단계, 이미지 2/3 Bosch 3727DEVS Motor Brushes  Replacement: 3 단계, 이미지 3/3
    • Using the T10 Torx Screwdriver, remove the four 9.7 mm screws securing the motor brushes to the housing.
    • After the screws are removed, both motor brushes can be lifted out of their position by hand.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Riddle
회원 가입일: 01/29/16
331 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 998
