소개
Purchase a new Power Cord. The sander should be unplugged from any power sources. Make sure you organize the removed screws, so you can reinstall them in the correct location.
필요한 것
Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
Lift the top cover off the sander.
이 단계에 사용된 도구:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Using the 2.5 mm Flathead Screwdriver, loosen the two screws securing the white and black wires to the On/Off Switch.
다른 한 분이 해당 안내서를 완성하였습니다.
