주요 콘텐츠로 건너뛰기
Bosch MFQ 36440 Disassembly
필요한 것
  1. Bosch MFQ 36440 Disassembly, Remove screws: 1 단계, 이미지 1개 중 1개
    • Remove 2x Torx screws (size 10) on the front
  2. Bosch MFQ 36440 Disassembly, Remove the grey front cover: 2 단계, 이미지 2개 중 1개 Bosch MFQ 36440 Disassembly, Remove the grey front cover: 2 단계, 이미지 2개 중 2개
    • Remove the front cover
    • Gently push downwards the cover, then pull it through the holes
    • Once it is detached at the top, slide the entire gray cover down
  3. Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: 3 단계, 이미지 3개 중 1개 Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: 3 단계, 이미지 3개 중 2개 Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: 3 단계, 이미지 3개 중 3개
    • The first step is somewhat tricky. Use a long screwdriver to release the first part at the top.
    • Continue your way all around the case.
    • The clip on top front is tricky a long and thin flat screwdriver is needed
    • The clip on very top is impossible to release you need to pry the two half’s carefully apart until the top releases
  4. Bosch MFQ 36440 Disassembly, Assembly: 4 단계, 이미지 2개 중 1개 Bosch MFQ 36440 Disassembly, Assembly: 4 단계, 이미지 2개 중 2개
    • Prop everything back into the half without the clips
    • Take care about the safety cam to be aligned in the cover
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Stanky
회원 가입일: 07/08/17
1,358 평판
안내서 6개를 작성함
2가이드 댓글
Hey, so what does “Continue your way all around the case” mean? I got the one clip open which you pictured, and then I got the case open just a tiny bit more, but now I’m stuck.
Could someone perhaps detail the last steps more? :(
Carsten Hagemann - 답글
When you put it together again use the side with the cable “channels”, it is way easier than with the other side.
Tobias Vdb - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 43
지난 30일: 179
전체 시간: 10,049
