필요한 것
Remove the front cover
Gently push downwards the cover, then pull it through the holes
Once it is detached at the top, slide the entire gray cover down
Continue your way all around the case.
The clip on top front is tricky a long and thin flat screwdriver is needed
The clip on very top is impossible to release you need to pry the two half’s carefully apart until the top releases
Prop everything back into the half without the clips
Take care about the safety cam to be aligned in the cover
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
Hey, so what does “Continue your way all around the case” mean? I got the one clip open which you pictured, and then I got the case open just a tiny bit more, but now I’m stuck.
Could someone perhaps detail the last steps more? :(
When you put it together again use the side with the cable “channels”, it is way easier than with the other side.
Tobias Vdb - 답글
