소개
Bei Deinem Bosch PMF 180 E ist der Stecker beschädigt? Mit dieser Anleitung kannst Du ihn austauschen!
필요한 것
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
다른 2명이 해당 안내서를 완성하였습니다.
첨부 문서
댓글 한 개
To right of green holder there is a looped black and white wire that goes underneath. Where does it attach to as mine is loose below coil, between coil and case. Tool just stopped working mid use. No burning smell and no other loose connections. There is a moulding.on case that it fits into but no attachment anywhere. Coil has a small dent where small bend in wire appears to have sat
MsMacGyver - 답글
