소개
Your plug is damaged on your Bosch PMF 180 E? With this guide, you can exchange it!
필요한 것
Repeat the steps in order to reassemble your device.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
irlanda님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
첨부 문서
댓글 한 개
To right of green holder there is a looped black and white wire that goes underneath. Where does it attach to as mine is loose below coil, between coil and case. Tool just stopped working mid use. No burning smell and no other loose connections. There is a moulding.on case that it fits into but no attachment anywhere. Coil has a small dent where small bend in wire appears to have sat
MsMacGyver - 답글
