소개
Use this guide to replace the gearbox in the Bosch PS21. If the clutch is not working, the gearbox will need to be replaced. Be sure to remove the battery before disassembling the device.
필요한 것
Locate the clip that binds the two halves of the outer casing together on the rear edge of the battery shaft. Remove the clip with the angled tweezers.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
