주요 콘텐츠로 건너뛰기
Bosch PS21 Trigger Replacement
필요한 것
  1. Bosch PS21 Trigger Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Pinch the two release tabs on the sides of the battery, and slide the battery out.
  2. Bosch PS21 Trigger Replacement, Trigger: 2 단계, 이미지 2개 중 1개 Bosch PS21 Trigger Replacement, Trigger: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    $3.99
    • Locate the clip that connects the two halves of the outer casing on the rear edge of the battery shaft. *Use the angled tweezers to remove the clip.
    • Place the tweezers in the groove on the inside of the clip. Use your other hand to firmly brace the drill and pull towards your body until the clip comes loose.
  3. Bosch PS21 Trigger Replacement: 3 단계, 이미지 3개 중 1개 Bosch PS21 Trigger Replacement: 3 단계, 이미지 3개 중 2개 Bosch PS21 Trigger Replacement: 3 단계, 이미지 3개 중 3개
    • Locate the eight 5.5 mm screws located on the upwards facing side of the drill.
    • Remove each screw using the T8 Torx driver, set aside in a safe place.
    • After removing all the screws, use a small or medium metal spudger remove the casing to expose the motor and trigger.
  4. Bosch PS21 Trigger Replacement: 4 단계, 이미지 2개 중 1개 Bosch PS21 Trigger Replacement: 4 단계, 이미지 2개 중 2개
    • Place a finger under the metal tab seen here and lift gently up to free the trigger mechanism.
    • Carefully grab the trigger assembly and gently pull upwards without taking too much out of place.
  5. Bosch PS21 Trigger Replacement: 5 단계, 이미지 2개 중 1개 Bosch PS21 Trigger Replacement: 5 단계, 이미지 2개 중 2개
    • Gently disconnect the two wires connecting the motor to the trigger utilizing a pair of pliers.
    • The trigger assembly is Part #:1607233422
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Getsemani Gonzalez
회원 가입일: 02/15/16
306 평판
안내서 2개를 작성함
IUPUI, Team 1-2, Harley Spring 2016 IUPUI, Team 1-2, Harley Spring 2016 회원
IUPUI-HARLEY-S16S1G2
4 회원들
안내서 4개를 작성함
2가이드 댓글
mine has always operated flawlessly, then I was putting a few screws in the bedroom shelf and it worked fine. picked it up to change rotation and it is froze up. the trigger operates the lite and the batteries are fresh. but it will not turn, tried to turn with a wrench but its locked ? motor? gear drive or trigger? It doesn’t even seem as if its trying to turn when you pull the trigger?
roadkingrick - 답글
The most difficult step in this process is disconnecting the black wire from the defective switch. The wire enters the switch block however there is no sign of a screw or fastening one can disconnect to remove that wire! That step is ‘glossed over’. Any enlightenment from anyone would be welcome.
Tony Savage - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 48
전체 시간: 5,904
