주요 콘텐츠로 건너뛰기
Bose Cinemate 10 Circuit Board Replacement
필요한 것
  1. Bose Cinemate 10 Circuit Board Replacement, Circuit Board: 1 단계, 이미지 1/2 Bose Cinemate 10 Circuit Board Replacement, Circuit Board: 1 단계, 이미지 2/2
    • Locate the cable input port, on the back of the device.
    • Remove the 2, PH1, 15mm screws.
  2. Bose Cinemate 10 Circuit Board Replacement: 2 단계, 이미지 1/3 Bose Cinemate 10 Circuit Board Replacement: 2 단계, 이미지 2/3 Bose Cinemate 10 Circuit Board Replacement: 2 단계, 이미지 3/3
    • Gently, pull the base of the A/V cable directly outward, away from the main body of the device.
    • Slide the plastic cover to the right, which should free the cover from the main body of the device.
  3. Bose Cinemate 10 Circuit Board Replacement: 3 단계, 이미지 1/3 Bose Cinemate 10 Circuit Board Replacement: 3 단계, 이미지 2/3 Bose Cinemate 10 Circuit Board Replacement: 3 단계, 이미지 3/3
    • Using your fingers, gently pull outward on the multi-colored wire bundle until the black plastic wire harness is visible.
    • Press on the latch on the black plastic wire harness, and pull the multi-colored wire bundle simultaneously. The cables should now be detached from the harness.
  4. Bose Cinemate 10 Circuit Board Replacement: 4 단계, 이미지 1/3 Bose Cinemate 10 Circuit Board Replacement: 4 단계, 이미지 2/3 Bose Cinemate 10 Circuit Board Replacement: 4 단계, 이미지 3/3
    • Using your fingers, grasp the edges of cable input port.
    • Gently pull the cable input port away from main body of device. The Circuit Board should now be completely separated from the main body of the device.
  5. Bose Cinemate 10 Circuit Board Replacement: 5 단계, 이미지 1/3 Bose Cinemate 10 Circuit Board Replacement: 5 단계, 이미지 2/3 Bose Cinemate 10 Circuit Board Replacement: 5 단계, 이미지 3/3
    • Press the tab on side of white plastic cable harness, and pull gently on the multi-colored wire bundle simultaneously. The cable should completely detach from the Circuit Board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Phillip Halverson
회원 가입일: 09/26/18
335 평판
안내서 2개 작성하였습니다
댓글 3개
Where do I buy the circuit board from.
frankiemo239 - 답글
Where do I find the circuit board from
frankiemo239 - 답글
Where can I buy a circuit board?
jeanne768 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 24
전체 시간: 1,970
