소개
This guide will allow you to access the subwoofers on either side of the Bose Cinemate 10. By removing the end caps, you can clean them or replace the subwoofers.
필요한 것
Using the blue plastic opening tool, pry up on the cloth covered end panel. The edge of end cap cover should separate from main body of device.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
