주요 콘텐츠로 건너뛰기
Bose Cinemate 10 Speaker Grill Cover Replacement
필요한 것
  1. Bose Cinemate 10 Speaker Grill Cover Replacement, Speaker Grill Cover: 1 단계, 이미지 1/2 Bose Cinemate 10 Speaker Grill Cover Replacement, Speaker Grill Cover: 1 단계, 이미지 2/2
    • Orient the Bose Cinemate 10 so that the Bose Label is facing frontward.
    • Rotate the speaker so that the botton barcode is visible.
  2. Bose Cinemate 10 Speaker Grill Cover Replacement: 2 단계, 이미지 1/3 Bose Cinemate 10 Speaker Grill Cover Replacement: 2 단계, 이미지 2/3 Bose Cinemate 10 Speaker Grill Cover Replacement: 2 단계, 이미지 3/3
    • Insert the blue plastic opening tool into the crevice directly beneath the Bose Logo.
    • Using the blue plastic opening tool, pry upwards.
    • Work the blue plastic opening tool along edge of the speaker towards the right end of the speaker prying along the way
    • Move the blue plastic opening tool back to center, and then work the plastic opening tool towards the left end of the speaker, prying along the way
  3. Bose Cinemate 10 Speaker Grill Cover Replacement: 3 단계, 이미지 1/3 Bose Cinemate 10 Speaker Grill Cover Replacement: 3 단계, 이미지 2/3 Bose Cinemate 10 Speaker Grill Cover Replacement: 3 단계, 이미지 3/3
    • Insert fingers into crevice between the grill cover and device base and forcefully pry upwards.
    • Continue prying until the Speaker Grill cover is completly detached.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Phillip Halverson
회원 가입일: 09/26/18
335 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 1,804
