주요 콘텐츠로 건너뛰기
Bose Cinemate 10 Subwoofer Replacement
필요한 것
  1. Bose Cinemate 10 Subwoofer Replacement, End Cap: 1 단계, 이미지 1/2 Bose Cinemate 10 Subwoofer Replacement, End Cap: 1 단계, 이미지 2/2
    • Using the blue plastic opening tool, pry up on the cloth covered end panel. The edge of end cap cover should separate from main body of device.
  2. Bose Cinemate 10 Subwoofer Replacement: 2 단계, 이미지 1/1
    • Using your fingers, lift up on the end cap cover until it separates completely from the main body of the device.
  3. Bose Cinemate 10 Subwoofer Replacement: 3 단계, 이미지 1/2 Bose Cinemate 10 Subwoofer Replacement: 3 단계, 이미지 2/2
    • Remove the 4, PH1, 15mm screws on the side speaker cover frame.
  4. Bose Cinemate 10 Subwoofer Replacement: 4 단계, 이미지 1/1
    • Remove speaker cover frame from main body of device.
  5. Bose Cinemate 10 Subwoofer Replacement, Subwoofer: 5 단계, 이미지 1/2 Bose Cinemate 10 Subwoofer Replacement, Subwoofer: 5 단계, 이미지 2/2
    • Remove the 4, PH1, 10 mm screws from the subwoofer frame.
  6. Bose Cinemate 10 Subwoofer Replacement: 6 단계, 이미지 1/2 Bose Cinemate 10 Subwoofer Replacement: 6 단계, 이미지 2/2
    • Using the blue plastic opening tool, pry up on the edge of the subwoofer frame.
    • Using your fingers, lift up on the subwoofer frame until it separates completely from the main body of the device.
  7. Bose Cinemate 10 Subwoofer Replacement: 7 단계, 이미지 1/3 Bose Cinemate 10 Subwoofer Replacement: 7 단계, 이미지 2/3 Bose Cinemate 10 Subwoofer Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using the curved precision tweezers, grasp end of wire.
    • Using the curved precision tweezers, unravel wire around blue metal post.
  8. Bose Cinemate 10 Subwoofer Replacement: 8 단계, 이미지 1/2 Bose Cinemate 10 Subwoofer Replacement: 8 단계, 이미지 2/2
    • After wire is completely unraveled, repeat steps 4 and 5, on red metal post.
    • Remove the speaker from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anthony Ledesma
회원 가입일: 09/26/18
130 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 1,333
