주요 콘텐츠로 건너뛰기
Bose Noise Cancelling Headphones 700 Ear Cushion Replacement
필요한 것
  1. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement, Ear Cushion: 1 단계, 이미지 2개 중 1개 Bose Noise Cancelling Headphones 700 Ear Cushion Replacement, Ear Cushion: 1 단계, 이미지 2개 중 2개
    • Optional: Remove the band around the ear cushions if you find it to be in the way while replacing the ear cushions.
  2. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 2 단계, 이미지 1개 중 1개
    • Take the old ear cushions off of the headphones using an iFixit opening tool.
    • Using the tool, go around the ear cushions from the inside or the outside of the cushions, and gently pry them off.
  3. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 3 단계, 이미지 3개 중 1개 Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 3 단계, 이미지 3개 중 2개 Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 3 단계, 이미지 3개 중 3개
    • Make sure that the ear cushion is for the correct side if that is specified for the ear cushions you are using.
    • Align the ear cushion with the slots in the correct places and press it onto the headphones.
  4. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 4 단계, 이미지 1개 중 1개
    • If you took the band off the headphones, put it back on.
    • Repeat steps 1-3 for the other side of the headphones.
결론
Based on the reviews of the various replacement ear cushions for the Bose Noise Canceling Headphones 700, the replacement ear cushions from the Bose website are the best if the noise-canceling ability of the headphones is a necessity. Otherwise, any other manufacturer for the ear cushions will work perfectly fine as long as they are made for these specific headphones.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Anjana Chilukuri
회원 가입일: 07/05/23
163 평판
안내서 1개를 작성함
2가이드 댓글
Anleitung ist sicher gut und zutreffend, zeigt aber leider keinen Bose 700 Kopfhörer.
Markus Scheuermann - 답글
J'ai utilisé ce tutoriel pour changer les coussinets de mon casque bose quietcomfort 35. C'est la même technique et marche très bien. Merci!
Attention toutefois, il n'est pas utile de détacher la bande entourant les coussinets, elle est de plus difficile à remettre dans le cas du QC35.
Natacha - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 18
지난 30일: 97
전체 시간: 4,280
