주요 콘텐츠로 건너뛰기
Bose Noise Cancelling Headphones 700 Ear Cushion Replacement
필요한 것
  1. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement, Ear Cushion: 1 단계, 이미지 1/2 Bose Noise Cancelling Headphones 700 Ear Cushion Replacement, Ear Cushion: 1 단계, 이미지 2/2
    • Optional: Remove the band around the ear cushions if you find it to be in the way while replacing the ear cushions.
  2. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 2 단계, 이미지 1/1
    • Take the old ear cushions off of the headphones using an iFixit opening tool.
    • Using the tool, go around the ear cushions from the inside or the outside of the cushions, and gently pry them off.
  3. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 3 단계, 이미지 1/3 Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 3 단계, 이미지 2/3 Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 3 단계, 이미지 3/3
    • Make sure that the ear cushion is for the correct side if that is specified for the ear cushions you are using.
    • Align the ear cushion with the slots in the correct places and press it onto the headphones.
  4. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 4 단계, 이미지 1/1
    • If you took the band off the headphones, put it back on.
    • Repeat steps 1-3 for the other side of the headphones.
결론
Based on the reviews of the various replacement ear cushions for the Bose Noise Canceling Headphones 700, the replacement ear cushions from the Bose website are the best if the noise-canceling ability of the headphones is a necessity. Otherwise, any other manufacturer for the ear cushions will work perfectly fine as long as they are made for these specific headphones.
다른 한 분이 해당 안내서를 완성하였습니다.
Anjana Chilukuri
회원 가입일: 07/05/23
139 평판
안내서 1개 작성함
Austin Community College, Team 1-2, Meigs Summer 2023 Austin Community College, Team 1-2, Meigs Summer 2023 회원
AUSTINCC-MEIGS-SU23S1G2
1 회원
안내서 2개 작성하였습니다
댓글 한 개
Anleitung ist sicher gut und zutreffend, zeigt aber leider keinen Bose 700 Kopfhörer.
Markus Scheuermann - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 28
30일 전: 116
전체 시간: 1,458
