주요 콘텐츠로 건너뛰기
Bose On-Ear headphones Ear Cushion Replacement
필요한 것
  1. Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: 1 단계, 이미지 1/3 Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: 1 단계, 이미지 2/3 Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: 1 단계, 이미지 3/3
    • Here is the Bose Tricore OE headset. Slightly worn and a torn left ear cushion
    • To remove an existing ear cushion one would simply be applying a bit of force between the ear pads and the housing. The ear cushion will simply snap off
    • This shows the snaps that attach the ear pad to the case.
  2. Bose On-Ear headphones Ear Cushion Replacement: 2 단계, 이미지 1/3 Bose On-Ear headphones Ear Cushion Replacement: 2 단계, 이미지 2/3 Bose On-Ear headphones Ear Cushion Replacement: 2 단계, 이미지 3/3
    • Since the ear cushion was already torn off on this one, simply clean the mating surfaces from all debris left by the old ear cushion
    • All left over foam and adhesive tape needs to be removed. This will ensure a proper fit.
    • Here is a look at the back of the replacement cushion.
  3. Bose On-Ear headphones Ear Cushion Replacement: 3 단계, 이미지 1/3 Bose On-Ear headphones Ear Cushion Replacement: 3 단계, 이미지 2/3 Bose On-Ear headphones Ear Cushion Replacement: 3 단계, 이미지 3/3
    • Position the cushion so that the orientation aligns the two holes with the two pins on the headphones.
    • Place the new ear cushion on the headphones ensuring the holes and pins are lined up.
    • A simple squeeze on the ear cushion will snap the plastic to the headphones.
  4. Bose On-Ear headphones Ear Cushion Replacement: 4 단계, 이미지 1/1
    • Good as new and ready to jam!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
781,527 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
32 회원들
안내서 531개 작성하였습니다
댓글 한 개
Thanks for showing the steps
Rajiv Garg - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 14
30일 전: 52
전체 시간: 7,285
