주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
해당 분해도는 수리 안내서가 아닙니다. Bose QuietComfort 35 수리는 자사의 서비스 설명서를 사용하세요.
  1. Bose QC25, QC35, & QC45 Teardown, Prepararations: 1 단계, 이미지 3개 중 1개 Bose QC25, QC35, & QC45 Teardown, Prepararations: 1 단계, 이미지 3개 중 2개 Bose QC25, QC35, & QC45 Teardown, Prepararations: 1 단계, 이미지 3개 중 3개
    • Have a small magnet to collect the tin screws, magnetize your screwdrivers with a 'magnetizer' . (Or by dragging it repeatedly across a magnet longitudinally to magnetize it)
  2. Bose QC25, QC35, & QC45 Teardown, Easy Part 1 - Take off chasis: 2 단계, 이미지 1개 중 1개
    • I wont waste time on the disassembly, because it all comes apart easily. Putting it back together is the hard part.
  3. Bose QC25, QC35, & QC45 Teardown, Putting it back together: 3 단계, 이미지 3개 중 1개 Bose QC25, QC35, & QC45 Teardown, Putting it back together: 3 단계, 이미지 3개 중 2개 Bose QC25, QC35, & QC45 Teardown, Putting it back together: 3 단계, 이미지 3개 중 3개
    • I gave up on replacing the headband when I saw how detailed the cabling is to the earpiece - it splits into 4 distinct soldered hair-thin wires which must be reattached. So knowing how sensitive the board must be to poor soldering, I closed it back up.
    • Take note that the black foam 'cup' for the microphone inside the ear cover is too small and the mic just pressed up against it. Dont struggle to get the mic into the foam cup. Close that up first.
  4. Bose QC25, QC35, & QC45 Teardown, The earphone side headband assembly: 4 단계, 이미지 3개 중 1개 Bose QC25, QC35, & QC45 Teardown, The earphone side headband assembly: 4 단계, 이미지 3개 중 2개 Bose QC25, QC35, & QC45 Teardown, The earphone side headband assembly: 4 단계, 이미지 3개 중 3개
    • This grey rotating joint slips into place on both molded sides. The cable is threaded through the headband, this joint, and the earphone outside before you find it soldered onto the motherboard. Just a tip: that think rose-colored clip in the main picture fits onto the band Curved-Side-Down.
  5. Bose QC25, QC35, & QC45 Teardown, Ignore the closed grey lid!: 5 단계, 이미지 3개 중 1개 Bose QC25, QC35, & QC45 Teardown, Ignore the closed grey lid!: 5 단계, 이미지 3개 중 2개 Bose QC25, QC35, & QC45 Teardown, Ignore the closed grey lid!: 5 단계, 이미지 3개 중 3개
    • Inside is only a battery! It takes about 15 minutes of glue scraping to pry this off carefully. Not worth it unless you need to replace the battery.
  6. Bose QC25, QC35, & QC45 Teardown, Headband side clamp /cover: 6 단계, 이미지 3개 중 1개 Bose QC25, QC35, & QC45 Teardown, Headband side clamp /cover: 6 단계, 이미지 3개 중 2개 Bose QC25, QC35, & QC45 Teardown, Headband side clamp /cover: 6 단계, 이미지 3개 중 3개
    • This cover need to both 'bite' with its 'teeth' into the cloth headband and screw together to clamp it onto the metal headband frame. You will adjust this for 5 minutes to get both at the same time.
    • See how the screw holes and the pink 'aligners' fit into the metal frame? You need that lined up while the teeth bite into the cloth part of the headband.
작성자
3다른 기여자 명과 함께
Paul Tast
회원 가입일: 09/17/16
984 평판
안내서 7개를 작성함
1가이드 댓글
Needs disassembly instructions, unhelpful
John Sutton - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 66
지난 30일: 316
전체 시간: 9,412
