주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide covers the QuietComfort 25 battery removal and replacement.
Warning. Sometimes, batteries and the compartments they come into contact with can become corroded. Corrosion appears as chalky-white or green. If you see that the battery or battery compartment is corroded, do not allow it to come into contact with your skin or eyes. Alkaline batteries can leak potassium hydroxide, an agent that is capable of burning, corroding, or destroying tissue.
  1. Locate the side designation in the interior of the earpiece. The battery compartment is located on the top of the right-side earpiece, accessible via the latched door.
    • Locate the side designation in the interior of the earpiece.
    • The battery compartment is located on the top of the right-side earpiece, accessible via the latched door.
  2. Do not allow battery corrosion to come into contact with your skin or eyes. Sometimes, batteries or the terminals they come into contact with can become corroded. Corrosion will appear as chalky-white or green.
    • Do not allow battery corrosion to come into contact with your skin or eyes.
    • Sometimes, batteries or the terminals they come into contact with can become corroded. Corrosion will appear as chalky-white or green.
    • If the compartment is not clean--coated with debris or corroded--use a cotton swab to carefully remove debris or corrosion from the terminal corrosion.
  3. Insert a new battery.
    • Insert a new battery.
    • Make sure that the polarity of the battery is aligned correctly to the diagram on the inside of the cartridge.
결론
When finished with this guide process, the Bose QuietComfort 25 should be able to be played with the functioning noise-cancelling feature.
다른 7명이 해당 안내서를 완성하였습니다.
Matt Jordan
회원 가입일: 2017년 01월 17일
708 평판
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 19
30일 전: 104
전체 시간: 6,259
