주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bose QuietComfort 35 Case Zipper Replacement
필요한 것
    1. Bose QuietComfort 35 Case Zipper Replacement, Assess the damage: 1 단계, 이미지 2개 중 1개 Bose QuietComfort 35 Case Zipper Replacement, Assess the damage: 1 단계, 이미지 2개 중 2개
      • The zipper is damaged beyond repair, and needs to be completely replaced
      댓글 쓰기
    2. Bose QuietComfort 35 Case Zipper Replacement, Open case: 2 단계, 이미지 2개 중 1개 Bose QuietComfort 35 Case Zipper Replacement, Open case: 2 단계, 이미지 2개 중 2개
      • Open case
      • Remove accessories
      댓글 쓰기
    3. Bose QuietComfort 35 Case Zipper Replacement, Exposing the seam: 3 단계, 이미지 3개 중 1개 Bose QuietComfort 35 Case Zipper Replacement, Exposing the seam: 3 단계, 이미지 3개 중 2개 Bose QuietComfort 35 Case Zipper Replacement, Exposing the seam: 3 단계, 이미지 3개 중 3개
      • Take one side of the case and start close to the place where both sides of the case are joined
      • Push the fabric with the teeth out and down, exposing the seam
      • The fabric should sort of snap in place against the sides of the case
      • Work your way around this side of the case
      댓글 쓰기
    4. Bose QuietComfort 35 Case Zipper Replacement, Exposing the seam: 4 단계, 이미지 2개 중 1개 Bose QuietComfort 35 Case Zipper Replacement, Exposing the seam: 4 단계, 이미지 2개 중 2개
      • Repeat on the other half of the case
      댓글 쓰기
    5. Bose QuietComfort 35 Case Zipper Replacement, Sewing pattern: 5 단계, 이미지 3개 중 1개 Bose QuietComfort 35 Case Zipper Replacement, Sewing pattern: 5 단계, 이미지 3개 중 2개 Bose QuietComfort 35 Case Zipper Replacement, Sewing pattern: 5 단계, 이미지 3개 중 3개
      • On each half, there is a soft piece of fabric that covers all the other seams and give the case a nice soft finish. The seam is visible on the outer part of the case, now that we pushed the teeth of the zipper down. It is held on by 2 threads
      • The first thread goes through the leather, makes a loop, and then goes back through the same hole. It then moves a few mm and repeats.
      • The second thread just goes through all the loops
      • Sew pattern schematic not to scale . It's just to get an idea of how the fabric is held on. The threads are pulled tight. They were most likely machine sewn
      댓글 쓰기
    6. Bose QuietComfort 35 Case Zipper Replacement, Cutting the thread: 6 단계, 이미지 3개 중 1개 Bose QuietComfort 35 Case Zipper Replacement, Cutting the thread: 6 단계, 이미지 3개 중 2개 Bose QuietComfort 35 Case Zipper Replacement, Cutting the thread: 6 단계, 이미지 3개 중 3개
      • Start anywhere where you have a good visibility and access to the outer thread
      • Take a needle and work it behind the thread, to create some space
      • Insert the tip of a pair of scissors or the blade of a knife into the space and cut the thread
      댓글 쓰기
    7. Bose QuietComfort 35 Case Zipper Replacement, Start pulling out the thread: 7 단계, 이미지 1개 중 1개
      • Moving to the next neighbouring stitch, use a pointy item to pull the thread out
      • I found that the cork screw tool of a swiss army knife worked well, as the point is a bit dull, thus not getting stuck if the fabric, but still pointy enough to work it behind the thread, allowing me to work faster. The shape of the cork screw opener also naturally helps to pull the thread out
      댓글 쓰기
    8. Bose QuietComfort 35 Case Zipper Replacement: 8 단계, 이미지 2개 중 1개 Bose QuietComfort 35 Case Zipper Replacement: 8 단계, 이미지 2개 중 2개
      • Work your way around the case, in both directions
      • The place where the halfs of the case connect, is a little messy, as that is where the sew starts and finishes, so there are extra stitches there for strength. Just cut threw them an pull them out
      • At some point you might want to cut the inner thread, so that is doesn't get in the way
      댓글 쓰기
    9. Bose QuietComfort 35 Case Zipper Replacement: 9 단계, 이미지 2개 중 1개 Bose QuietComfort 35 Case Zipper Replacement: 9 단계, 이미지 2개 중 2개
      • Once you get to one end, you can start lifting part of the fabric up, as you go along
      댓글 쓰기
    10. Bose QuietComfort 35 Case Zipper Replacement, Dealing with the airplane jack: 10 단계, 이미지 3개 중 1개 Bose QuietComfort 35 Case Zipper Replacement, Dealing with the airplane jack: 10 단계, 이미지 3개 중 2개 Bose QuietComfort 35 Case Zipper Replacement, Dealing with the airplane jack: 10 단계, 이미지 3개 중 3개
      • Once you get to the airplane adapter, you will encounter a problem
      • The airplane adapter socket is glued to the inner lining
      • You either remove it or you can just pull it away from the side of the case enough to work behind it. This requires a bit of force to remove the top layer of glue
      • If you remove the socket completely, be carful not to rip the lining. You made need some heat or chemical to dissolve the glue
      댓글 쓰기
    11. Bose QuietComfort 35 Case Zipper Replacement: 11 단계, 이미지 3개 중 1개 Bose QuietComfort 35 Case Zipper Replacement: 11 단계, 이미지 3개 중 2개 Bose QuietComfort 35 Case Zipper Replacement: 11 단계, 이미지 3개 중 3개
      • Remove the remaining stitches and peel off the fabric from the back of the socket
      댓글 쓰기
    12. Bose QuietComfort 35 Case Zipper Replacement: 12 단계, 이미지 3개 중 1개 Bose QuietComfort 35 Case Zipper Replacement: 12 단계, 이미지 3개 중 2개 Bose QuietComfort 35 Case Zipper Replacement: 12 단계, 이미지 3개 중 3개
      • The zipper tape is still held to the case by one thread
      • Cut it and work your way around the case, the same way as for the first fabric, to undo the seam
      • On the inside there are 2 seams: one that holds the tape to the leather, and one that holds the outer fabric (the sort of "back pocket" of the case) to the leather. To avoid mistakes, undo the seam from the exterior of the case (orange stitches)
      댓글 쓰기
    13. Bose QuietComfort 35 Case Zipper Replacement: 13 단계, 이미지 2개 중 1개 Bose QuietComfort 35 Case Zipper Replacement: 13 단계, 이미지 2개 중 2개
      • Once you have removed the seam all the way around, the zipper tap will slide off that half of the case
      댓글 쓰기
    14. Bose QuietComfort 35 Case Zipper Replacement, Repeat other half: 14 단계, 이미지 2개 중 1개 Bose QuietComfort 35 Case Zipper Replacement, Repeat other half: 14 단계, 이미지 2개 중 2개
      • We now repeat the process on the other half of the case
      • Chose a spot on the seam and insert a needle to make space between the fabric and the thread
      • Insert a knife or scissors in the space and cut the thread
      댓글 쓰기
    15. Bose QuietComfort 35 Case Zipper Replacement: 15 단계, 이미지 1개 중 1개
      • Work your way around the case the same way as the other half, pulling the thread out, stitch by stitch
      댓글 쓰기
    16. Bose QuietComfort 35 Case Zipper Replacement, Dealing with the stopper knot: 16 단계, 이미지 3개 중 1개 Bose QuietComfort 35 Case Zipper Replacement, Dealing with the stopper knot: 16 단계, 이미지 3개 중 2개 Bose QuietComfort 35 Case Zipper Replacement, Dealing with the stopper knot: 16 단계, 이미지 3개 중 3개
      • When getting to the place where the soft fabric overlaps, there will be a complicated mess of threads, and it will be simpler to cut them, and pull them out, rather than try to pull on them in the correct order
      댓글 쓰기
    17. Bose QuietComfort 35 Case Zipper Replacement: 17 단계, 이미지 3개 중 1개 Bose QuietComfort 35 Case Zipper Replacement: 17 단계, 이미지 3개 중 2개 Bose QuietComfort 35 Case Zipper Replacement: 17 단계, 이미지 3개 중 3개
      • Once the thread has been removed all around, pull the soft concealer fabric off
      댓글 쓰기
    18. Bose QuietComfort 35 Case Zipper Replacement: 18 단계, 이미지 3개 중 1개 Bose QuietComfort 35 Case Zipper Replacement: 18 단계, 이미지 3개 중 2개 Bose QuietComfort 35 Case Zipper Replacement: 18 단계, 이미지 3개 중 3개
      • The tape is still held on, like for the other half, by a single thread.
      • On the inner bottom section of this half, there are 2 seams. One is to hold the inner pocket, which we don't need to remove. So as before, undo the seam from the outside.
      댓글 쓰기
    19. Bose QuietComfort 35 Case Zipper Replacement: 19 단계, 이미지 2개 중 1개 Bose QuietComfort 35 Case Zipper Replacement: 19 단계, 이미지 2개 중 2개
      • Another point of note, is where the two half of the case were joined: There are 2 seams here as well. One is holding the tape to the leather, and the other is holding the soft stopper fabric to the tape.
      • It's easier to remove the seam for the stopper fabric later, but if you cut it and pull on it, it's no big deal
      댓글 쓰기
결론
Your case should now be fixed.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sam
회원 가입일: 09/13/14
920 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 24
지난 30일: 74
전체 시간: 2,942
