주요 콘텐츠로 건너뛰기
Bose Solo 5 Sound Bar Control Panel Replacement
필요한 것
  1. Bose Solo 5 Sound Bar Control Panel Replacement, Control Panel: 1 단계, 이미지 1/1
    • Lay Bose Solo 5 with speakers facing away from you and bottom side facing upward.
  2. Bose Solo 5 Sound Bar Control Panel Replacement: 2 단계, 이미지 1/2 Bose Solo 5 Sound Bar Control Panel Replacement: 2 단계, 이미지 2/2
    • Remove the five 18.25mm screws with the Phillips #2 screw driver.
  3. Bose Solo 5 Sound Bar Control Panel Replacement: 3 단계, 이미지 1/1
    • Remove the gold plates snap connector from the circuit board by pulling it apart.
  4. Bose Solo 5 Sound Bar Control Panel Replacement: 4 단계, 이미지 1/1
    • Using the plastic opening tool, lift the circuit board up and remove from housing.
  5. Bose Solo 5 Sound Bar Control Panel Replacement: 5 단계, 이미지 1/2 Bose Solo 5 Sound Bar Control Panel Replacement: 5 단계, 이미지 2/2
    • Disconnect the cords running to the white connecter by pulling up on the tab until it is disconnected completely.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Emma
회원 가입일: 10/05/18
500 평판
안내서 3개 작성하였습니다
Sam Houston State, Team S15-G7, Blackburne Fall 2018 Sam Houston State, Team S15-G7, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S15G7
2 회원들
안내서 4개 작성하였습니다
댓글 5개
Does anyone know where to buy a replacement logic board? I’ve been searching for a while now, no dice.
Tyler Barney - 답글
hallo und wo bekomme ich das Ersatzteil die Platiene 73252 Delta 3
APP TISCHNER - 답글
Has anyone had any luck finding the same board. Im looking.
ka.wells - 답글
I know how to open it. What I don't know is where to buy one.
szanti - 답글
If anyone was able to find the board, it wuold be great to know where did you find it. Looking for this board during months...
Juan Ramirez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 24
30일 전: 114
전체 시간: 13,044
