주요 콘텐츠로 건너뛰기
Bose Solo 5 Sound Bar Indicator Light Replacement
필요한 것
  1. Bose Solo 5 Sound Bar Indicator Light Replacement, Indicator Light: 1 단계, 이미지 1개 중 1개
    • Lay the Bose Solo 5 on its side, with the speakers facing away from you. This orientation will result in the bottom of the speaker facing upwards.
  2. Bose Solo 5 Sound Bar Indicator Light Replacement: 2 단계, 이미지 1개 중 1개
    • Remove five 18.25mm screws with a Phillips #2 screw driver.
  3. Bose Solo 5 Sound Bar Indicator Light Replacement: 3 단계, 이미지 1개 중 1개
    • Gently remove the gold plates and the snap connector from the circuit board by pulling it apart.
  4. Bose Solo 5 Sound Bar Indicator Light Replacement: 4 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, slightly lift the circuit board up and remove it from the housing.
  5. Bose Solo 5 Sound Bar Indicator Light Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the cords running to the white connector by pulling upon the tab until it is disconnected completely.
  6. Bose Solo 5 Sound Bar Indicator Light Replacement: 6 단계, 이미지 1개 중 1개
    • Locate the two clear LED receptors and note that one has two prongs and the other has three prongs.
  7. Bose Solo 5 Sound Bar Indicator Light Replacement: 7 단계, 이미지 2개 중 1개 Bose Solo 5 Sound Bar Indicator Light Replacement: 7 단계, 이미지 2개 중 2개
    • Locate on the back of the control panel where it states LED 902, 903, 904, and 905.
  8. Bose Solo 5 Sound Bar Indicator Light Replacement: 8 단계, 이미지 2개 중 1개 Bose Solo 5 Sound Bar Indicator Light Replacement: 8 단계, 이미지 2개 중 2개
    • If there is any debris located in these locations, use the spudger tool to thoroughly clean the area.
결론
To reassemble the sound bar, follow the steps listed above in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Emma
회원 가입일: 10/05/18
506 평판
안내서 3개를 작성함
Sam Houston State, Team S15-G7, Blackburne Fall 2018 Sam Houston State, Team S15-G7, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S15G7
2 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 35
전체 시간: 5,804
