소개
This is a step-by-step guide to replacing the indicator light on a Bose Solo 5 Sound Bar (Model # 732522-1110). The Indicator light on this speaker will show when the system is on, and shows the status of the system when in operation. The repair process is classified as a moderate difficulty, and does not require any specialized skills.
필요한 것
Lay the Bose Solo 5 on its side, with the speakers facing away from you. This orientation will result in the bottom of the speaker facing upwards.
To reassemble the sound bar, follow the steps listed above in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
