주요 콘텐츠로 건너뛰기
Bose Solo 5 Sound Bar Speaker Replacement
필요한 것
  1. Bose Solo 5 Sound Bar Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Lay Bose Solo 5 on its top side with the speakers facing away from you.
  2. Bose Solo 5 Sound Bar Speaker Replacement: 2 단계, 이미지 1/2 Bose Solo 5 Sound Bar Speaker Replacement: 2 단계, 이미지 2/2
    • Remove the two screws located at the outer edge of the backside with a Phillips head screwdriver.
  3. Bose Solo 5 Sound Bar Speaker Replacement: 3 단계, 이미지 1/1
    • Lay the speaker on its backside with the speakers facing up. Wedge the plastic opening tool into the crack where the protective wire screen meets the housing. Pry apart until you create enough room for your fingers.
  4. Bose Solo 5 Sound Bar Speaker Replacement: 4 단계, 이미지 1/2 Bose Solo 5 Sound Bar Speaker Replacement: 4 단계, 이미지 2/2
    • Pull the screen gently away from the housing to reveal the two speakers with your fingers.
  5. Bose Solo 5 Sound Bar Speaker Replacement: 5 단계, 이미지 1/3 Bose Solo 5 Sound Bar Speaker Replacement: 5 단계, 이미지 2/3 Bose Solo 5 Sound Bar Speaker Replacement: 5 단계, 이미지 3/3
    • Remove the 4 screws in each corner of the speaker to remove it from the housing.
  6. Bose Solo 5 Sound Bar Speaker Replacement: 6 단계, 이미지 1/2 Bose Solo 5 Sound Bar Speaker Replacement: 6 단계, 이미지 2/2
    • Peel back the styrofoam on the speaker & disconnect the yellow & brown wires by sliding them off the receptor.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Chase Cooper
회원 가입일: 10/09/18
220 평판
안내서 1개 작성함
Sam Houston State, Team S15-G7, Blackburne Fall 2018 Sam Houston State, Team S15-G7, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S15G7
2 회원들
안내서 4개 작성하였습니다
댓글 한 개
Well opening the case affect its original sound tuning or will it affect the performance ?
Saket Adhau - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 27
30일 전: 148
전체 시간: 13,150
