이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Lay the speaker flat on its back, balancing on the battery.
Remove the four rubber disks that cover the screws on the bottom of the speaker.
Follow the battery replacement guide to remove the battery
Now, remove the four 16mm #2 screws on the bottom of the speaker. This will allow the bottom plate to be removed.
Use a T15 Torx screwdriver to remove the dock from the base. Be careful not to damage the ribbon during this step.
Remove the three 6mm T8 torques screws that hold the dock connector together and pull the top and bottom pieces apart.
Once the pieces are separated, the dock connector can be lifted out of the slot.
Using tweezers or your fingers, unplug the two ribbon connectors from the board.
다른 6명이 해당 안내서를 완성하였습니다.
