주요 콘텐츠로 건너뛰기
Bose SoundDock Portable v2 Remote Battery Replacement
필요한 것
  1. Bose SoundDock Portable v2 Remote Battery Replacement, Remote Battery: 1 단계, 이미지 1/1
    • Using a quarter, turn the battery cover 1/8th of a turn counterclockwise.
  2. Bose SoundDock Portable v2 Remote Battery Replacement: 2 단계, 이미지 1/2 Bose SoundDock Portable v2 Remote Battery Replacement: 2 단계, 이미지 2/2
    • Remove cover and battery. The new battery should be placed with the positive (flat) side facing up.
    • The correct battery for your remote is a CR2032. You may also use a DL2032.
결론
Brodie Sutherland
회원 가입일: 04/14/15
303 평판
안내서 1개 작성함
Cal Poly, Team 4-1, Maness Spring 2015 Cal Poly, Team 4-1, Maness Spring 2015 회원
CPSU-MANESS-S15S4G1
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
We have a Bose Wave radio w/remote. This remote is not the one shown here with a screw for the battery compartment. It's the type w/a sliding holder for the battery on the south end (bottom of the battery). Someone went to replace the battery and shoved the holder in upside down I believe. Consequently the holder will not come out all the way.
There must be a way to get it out without forcing it. There's a pinch clip you have to either squeeze or move to the left to disengage it from the locked position and free it up. Any ideas as to how to accomplish this? We appreciate a reply back so this would make our Christmas better.
Merry Christmas & Happy Holidays! Cheers!
asbirdiesingh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 16
30일 전: 126
전체 시간: 13,560
