주요 콘텐츠로 건너뛰기
Bose SoundDock Portable v2 Speaker Replacement
필요한 것
  1. Bose SoundDock Portable v2 Speaker Replacement, Speaker: 1 단계, 이미지 1/3 Bose SoundDock Portable v2 Speaker Replacement, Speaker: 1 단계, 이미지 2/3 Bose SoundDock Portable v2 Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Gently pry the front mesh cover off of the SoundDock using a metal spudger.
    • The mesh is held on by small velcro strips so if you hear a tearing sound it is just the velcro coming apart
  2. Bose SoundDock Portable v2 Speaker Replacement: 2 단계, 이미지 1/2 Bose SoundDock Portable v2 Speaker Replacement: 2 단계, 이미지 2/2
    • Remove the four 16mm #2 screws holding the speaker to the base using a #2 screwdriver
    • Gently lift the speaker from the base.
    • Do not lift the speaker to far out of the base, you may damage the wires.
  3. Bose SoundDock Portable v2 Speaker Replacement: 3 단계, 이미지 1/1
    • You will notice 2 coils of wire around the speaker's input tabs. Slide these coils off as un-winding the wires may break the wires. Slide the coils around your new driver.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Evan Low
회원 가입일: 04/14/15
551 평판
안내서 4개 작성하였습니다
Cal Poly, Team 4-1, Maness Spring 2015 Cal Poly, Team 4-1, Maness Spring 2015 회원
CPSU-MANESS-S15S4G1
4 회원들
안내서 5개 작성하였습니다
댓글 5개
I am unsure of what to do in step #3…
Is the purpose to remove the speaker completely and place a brand new one? (Making sure not to pull the old speaker too far out as to not break any wire… ) ???
Edited comment:
I am not sure what they mean by "pins".
vero198099 - 답글
Hi I just accidently pushed in that dome part in the middle a little and now it distorts. I tried using a vacuum but it didnt work. Please help!!!!!!!!
AJ Grape - 답글
Try to see if there’s any way you can reduce the nozzle size of the vacuum cleaner you’re using - this should increase the flow rate, and possibly the amount of force applied over such a small area.
Alternatively, you can use a very very fine needle, bend the end of it, and use it to “hook” the cone. This method is really a last resort, as you want to avoid making even the smallest of holes.
Absolute last resort is replacing the speaker, which if you can find a replacement, should be pretty easy.
Colm Donnelly -
Need help love this speaker when it’s played loud it makes a load noise when the base is on changed aux lead think it’s the speaker what do I do
Chantelle Webb - 답글
How do you cut on without remote
Chad Davenport - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 31
전체 시간: 11,789
