주요 콘텐츠로 건너뛰기
Bose SoundDock XT Logic Board Replacement
필요한 것
  1. Bose SoundDock XT Logic Board Replacement, Logic Board: 1 단계, 이미지 1/1
    • Remove the six # 1 Phillips head screws from the bottom panel.
  2. Bose SoundDock XT Logic Board Replacement: 2 단계, 이미지 1/1
    • After removing the bottom plate, you will have visibility of the logic board. Using a plastic opening tool, lift the small black latch holding the ribbon cable. Slide the ribbon cable loose from the logic board.
  3. Bose SoundDock XT Logic Board Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Next, using pointed nose tweezers, remove the 4-wire white connector from the logic board by wiggle back and forth while lifting until the connector is disconnected from the board.
    • Metal pointed nose tweezers may cause damage if used improperly.
  4. Bose SoundDock XT Logic Board Replacement: 4 단계, 이미지 1/1
    • Remove the remaining 8mm length # 2 Phillips head screws holding the motherboard in place.
  5. Bose SoundDock XT Logic Board Replacement: 5 단계, 이미지 1/2 Bose SoundDock XT Logic Board Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    구매
    • Record the order of the 6 wires soldered to the board.
    • Using a hot soldering iron and either a solder sucker or de-soldering wick, remove the solder from the 6 wires highlighted on the photo in red.
    • Soldering iron may cause damage to the device if used improperly.
  6. Bose SoundDock XT Logic Board Replacement: 6 단계, 이미지 1/1
    • Replace old logic board with the new logic board. Place the wires into the solder holes and solder in place. Reassemble the SoundDock.
    • Make sure the wires are in the correct order using the recorded pattern from the wire removal step 3.
결론
To reassemble your device, follow these instructions in reverse order. With proper execution of these steps, you will be able to replace your logic board and enjoy the sound of your SoundDock XT.
다른 4명이 해당 안내서를 완성하였습니다.
redacted
회원 가입일: 09/29/15
288 평판
안내서 2개 작성하였습니다
IUPUI, Team 1-4, Hagerty Fall 2015 IUPUI, Team 1-4, Hagerty Fall 2015 회원
IUPUI-HAGERTY-F15S1G4
5 회원들
안내서 3개 작성하였습니다
댓글 한 개
Hi, one question, where can i buy the replacement logic board?
Nahir Romero - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 21
전체 시간: 2,180
