주요 콘텐츠로 건너뛰기
Bose SoundLink Color Outer Casing Replacement
필요한 것
  1. Bose SoundLink Color Outer Casing Replacement, Outer Casing: 1 단계, 이미지 1/2 Bose SoundLink Color Outer Casing Replacement, Outer Casing: 1 단계, 이미지 2/2
    • Four round, plastic plugs are located on the back of the device.
    • Using a metal spudger, carefully pry up the plastic covers.
    • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
  2. Bose SoundLink Color Outer Casing Replacement: 2 단계, 이미지 1/2 Bose SoundLink Color Outer Casing Replacement: 2 단계, 이미지 2/2
    • Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
    • Some of these use T15 "Star" 5-point Torx security screws instead of the more common 6-point ones.
  3. Bose SoundLink Color Outer Casing Replacement: 3 단계, 이미지 1/2 Bose SoundLink Color Outer Casing Replacement: 3 단계, 이미지 2/2
    • Carefully open up the casing.
    • The top button pad may need to be re-glued upon installing the new casing.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Michael Thorn
회원 가입일: 03/31/16
557 평판
안내서 3개 작성하였습니다
댓글 12개
When I search for a 1.8 cm Torx Plus TR drill bit, I see a whole set from Amazon. Is there a particular number or head size just so I can purchase one drill bit?
jwm82 - 답글
Hey, did you find out what size screwdriver you need?
kestis155 -
yes its the number 5 torque
art -
dose anyone know where to buy the outer casing for these? i need a mint colored one.
idixon16 - 답글
I need more information on the Torx Plus bit can you provide the exact size as you used. The 1.8cm is not easy to search for. Brand and exact size number would help.
Joseph - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 29
30일 전: 116
전체 시간: 29,189
