이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If you are experiencing any audio issues with the lower frequency sounds (the bass) such as distortion, muffling, quietness, or total absence of sound, you may need to replace your bass speaker.
필요한 것
Remove the four 12.5 mm screws using a Philips #2 screwdriver.
You will now be able to remove the bass speaker.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 2개
Where can I buy this bass speaker (Bose SoundLink III)?
