이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If you notice any major damage to your charging port that prevents you from charging your device, you may need to replace your charging port.
필요한 것
Remove the two 12.5 mm screws on either side of the charging port using a Torx T10 screwdriver.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 13개
Hello, This is an excellent resource. One thing, you did not say, or I did not see, where to purchase the actual usb port. Where can I locate one and this would be for a Bose Soundlink II.
Thank you,
Jim
jp7868@gmail.com
HI, thanks a lot for the instructions, any idea where i acn purchase the charging port full part
thanks
Carlos
I would like to know where i can buy the replacement part
Also would love to know where to purchase the required replacement MicroUSB Port. I'm searching and if I find anything compatible I will contact anyone else who posts to this thread.
