주요 콘텐츠로 건너뛰기
Bose SoundLink Mini Button Switch Circuit Board Replacement
필요한 것
  1. Bose SoundLink Mini Button Switch Circuit Board Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
  2. Bose SoundLink Mini Button Switch Circuit Board Replacement: 2 단계, 이미지 2개 중 1개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 2 단계, 이미지 2개 중 2개
    • While holding the cover back, pull straight up on the battery to remove it.
  3. Bose SoundLink Mini Button Switch Circuit Board Replacement, Front/Back Protective Grille: 3 단계, 이미지 1개 중 1개
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
  4. Bose SoundLink Mini Button Switch Circuit Board Replacement: 4 단계, 이미지 2개 중 1개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 4 단계, 이미지 2개 중 2개
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  5. Bose SoundLink Mini Button Switch Circuit Board Replacement: 5 단계, 이미지 2개 중 1개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 5 단계, 이미지 2개 중 2개
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  6. Bose SoundLink Mini Button Switch Circuit Board Replacement: 6 단계, 이미지 2개 중 1개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 6 단계, 이미지 2개 중 2개
    • Repeat steps to remove the back grille.
  7. Bose SoundLink Mini Button Switch Circuit Board Replacement, Battery Cover: 7 단계, 이미지 2개 중 1개 Bose SoundLink Mini Button Switch Circuit Board Replacement, Battery Cover: 7 단계, 이미지 2개 중 2개
    • Remove the four 15.0 mm screws on the left and the four 9.0 mm screws on the right using the T8 Torx Screwdriver.
  8. Bose SoundLink Mini Button Switch Circuit Board Replacement: 8 단계, 이미지 2개 중 1개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the circuit board by pushing it with your index finger in the direction shown while using a nylon or metal spudger to lift it up and out of place.
  9. Bose SoundLink Mini Button Switch Circuit Board Replacement: 9 단계, 이미지 2개 중 1개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 9 단계, 이미지 2개 중 2개
    • Carefully pull on the battery cover until the rubber tab slides out of the aluminum casing.
  10. Bose SoundLink Mini Button Switch Circuit Board Replacement, Button Switch Circuit Board: 10 단계, 이미지 1개 중 1개
    • Remove the sponge (save for later replacement) and gently flip the black tab 90 degrees to release the connectors grip on the ribbon cable. Remove the ribbon cable from the connector.
    • The black tab must be flipped up in order to reinsert the ribbon cable on reassembly.
  11. Bose SoundLink Mini Button Switch Circuit Board Replacement: 11 단계, 이미지 3개 중 1개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 11 단계, 이미지 3개 중 2개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 11 단계, 이미지 3개 중 3개
    • Use a Metal Spudger to pry up the plastic divider.
  12. Bose SoundLink Mini Button Switch Circuit Board Replacement: 12 단계, 이미지 2개 중 1개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 12 단계, 이미지 2개 중 2개
    • When removing the plastic divider be careful not to damage the wire strip sliding through it.
  13. Bose SoundLink Mini Button Switch Circuit Board Replacement: 13 단계, 이미지 2개 중 1개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 13 단계, 이미지 2개 중 2개
    • Reach through the battery compartment hole and unplug the power strip shown.
  14. Bose SoundLink Mini Button Switch Circuit Board Replacement: 14 단계, 이미지 3개 중 1개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 14 단계, 이미지 3개 중 2개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 14 단계, 이미지 3개 중 3개
    • Remove both circuit boards by wiggling them up and out of the casing.
    • Unplug the speaker wires connected and fully remove both circuit boards.
    • When unplugging the speaker wires, squeeze the white connector piece to release the wires.
  15. Bose SoundLink Mini Button Switch Circuit Board Replacement: 15 단계, 이미지 2개 중 1개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 15 단계, 이미지 2개 중 2개
    • Unhook the speaker wires clipped onto the button switch circuit board.
  16. Bose SoundLink Mini Button Switch Circuit Board Replacement: 16 단계, 이미지 3개 중 1개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 16 단계, 이미지 3개 중 2개 Bose SoundLink Mini Button Switch Circuit Board Replacement: 16 단계, 이미지 3개 중 3개
    • Use a nylon or metal spudger to slightly lift up on the button switch circuit board.
    • Pull the button switch circuit board straight out from the casing.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Jordan Smith
회원 가입일: 10/01/15
935 평판
안내서 4개를 작성함
Cal Poly, Team 1-23, Maness Fall 2015 Cal Poly, Team 1-23, Maness Fall 2015 회원
CPSU-MANESS-F15S1G23
4 회원들
안내서 24개를 작성함
12가이드 댓글
Hello
Where I can buy circuit
candellaaria - 답글
Yes were can we get the replacement part? ?
sonny goddin - 답글
Hi sonny,
did you find this part ? (the first circuit board)
luc.lacouture -
Hi
Can you get the relacement part for the mini II or is it the same - and if
- where and how to order for delivery to Europe?
Andreas Burckhart - 답글
Kindly can you tell me is th bose Soundlink mini first generation has an update or not, because it started no charge and the ember ligy keep flashing and some times reed color , I bought a new battery but still the same now it’s playing up
Moqdam Aljwrany - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 82
지난 30일: 440
전체 시간: 38,086
