주요 콘텐츠로 건너뛰기
Bose SoundLink Mini Front/Back Protective Grille Replacement
필요한 것
  1. Bose SoundLink Mini Front/Back Protective Grille Replacement, Front/Back Protective Grille: 1 단계, 이미지 1개 중 1개
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
  2. Bose SoundLink Mini Front/Back Protective Grille Replacement: 2 단계, 이미지 2개 중 1개 Bose SoundLink Mini Front/Back Protective Grille Replacement: 2 단계, 이미지 2개 중 2개
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  3. Bose SoundLink Mini Front/Back Protective Grille Replacement: 3 단계, 이미지 2개 중 1개 Bose SoundLink Mini Front/Back Protective Grille Replacement: 3 단계, 이미지 2개 중 2개
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  4. Bose SoundLink Mini Front/Back Protective Grille Replacement: 4 단계, 이미지 2개 중 1개 Bose SoundLink Mini Front/Back Protective Grille Replacement: 4 단계, 이미지 2개 중 2개
    • Repeat steps to remove the back grille.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jordan Smith
회원 가입일: 10/01/15
935 평판
안내서 4개를 작성함
Cal Poly, Team 1-23, Maness Fall 2015 Cal Poly, Team 1-23, Maness Fall 2015 회원
CPSU-MANESS-F15S1G23
4 회원들
안내서 24개를 작성함
7가이드 댓글
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
krisskuli - 답글
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Peter Bacher - 답글
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Peter Bacher - 답글
Where can I purchase the grill?
Ronald Roden Jr - 답글
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
Pranjal Vishwakarma - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 22
지난 30일: 110
전체 시간: 14,656
